Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Ampmeter
Janicholson
01-09-2013 14:20:32
If you do, you will have the gauge operating all the time ign. off or on. To make it operate only when the tractor is on. ground the same terminal that is grounded on your battery, and hook the other lead to the ignition switch. (assumes a battery ignition). if a mag, you could put a on off switch for the volt meter.
The wires from the charging system and to the starter switch and to the lights from the amp meter can be hooked to a common terminal, lug, or junction not grounded. (well insulated) Jim
Janicholson
01-09-2013 14:21:23
 Re: Ampmeter in reply to Janicholson, 01-09-2013 14:20:32
Were you able to adjust the regulator? Jim
