Have you seen this?-
I didn't realize that Farmall was making a six-cylinder diesel in the 1930's and if the advertisement was correct it "that was crankable by hand".
Fastest F-12 I ever saw. I cultivated corn with one for a neighbor about 1959, and I really wasn't impressed. It ran good but the cultivators were pretty clumsy compared to our John Deere H, and high gear was so slow I had to drive a post in the ground to see if I was moving. Had to be a whole bunch better than horses, but since I never used horses I can't compare.
(quoted from post at 19:06:24 01/07/13) I didn't realize that Farmall was making a six-cylinder diesel in the 1930's and if the advertisement was correct it "that was crankable by hand".
It was a gas start 4 cylinder that automatically switched fuels after starting. The other 40 series tractors, the WA and WK were 6 cylinder.
There were several... 7 I think...different transmission speed combinations for the F12. the rubber equipped ones had faster gearsets. They are identified with a letter code stamped into the back of the rear casting above and left of the pto.
(quoted from post at 09:32:49 01/08/13) By chance do you have those codes?
Guess there were 6
Code..Part #..............Gear=MPH
F- Standard trans 1=2.27, 2=2.98, 3=3.84, R=2.28
K- 27535D 1=2.27, 2=3.81, 3=6.60, R=2.28
L - 23535D +37503D 1=3.25, 2=5.50, 3=9.58, R=3.25
M- 30252D 1=2.27, 2=2.98, 3=6.30, R=2.28
X- 37503D 1=3.25, 2=4.25, 3=5.50, R=3.25
Z- 30252D+37503D 1=3.25, 2=4.25, 3=9.58, R=3.25
