Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Need Battery Cable Lengths for Key Start Farmall 140
MisterT
01-04-2013 08:58:29
The solder type of lugs have the solder already in them. Just slip it onto the cable and then heat it.
Welding cable will work, but it is not the same stuff as battery cable is made of.
RTR
01-04-2013 13:04:15
 Re: Need Battery Cable Lengths for Key Start Farmall 140 in reply to MisterT, 01-04-2013 08:58:29
WOW, well I wish I knew that! That is even easier than the clamp type and so much more durable and reliable!! Thanks for the tip. I have the flux and propane torch handy to do that too. How would you use flux with them since it has solder built in? Just spread some around inside the lug??
MisterT
01-04-2013 13:08:39
 Re: Need Battery Cable Lengths for Key Start Farmall 140 in reply to RTR, 01-04-2013 13:04:15
Crimping is even better than soldering, but you need some special tools to do the crimping. The best battery cable ends and lugs are made of heavy, cast copper, and are crimped on.
