TractorLinks.com
Show Parts for Model:
Re: Need Battery Cable Lengths for Key Start Farmall 140
RTR
01-04-2013 08:53:34
Actually got a pile of those things in the shop but never have used them. Always use the clamp on type if I needed to replace an end.....even though I hate those things. How do you attach the solder type lugs? What type of solder would I use to affix them.? I think all I have is the small electrical solder. We might have a roll of the larger solder (about size of 10 ga wire). What is used for those lugs?
rustred
01-04-2013 14:58:54
 Re: Need Battery Cable Lengths for Key Start Farmall 140 in reply to RTR, 01-04-2013 08:53:34
i buy my cable at the case ih dealer in about 8ft pieces at a time. i get them to crip a pos. and neg. terminal on each end. then when i need a cable i just cut it to length the + or - end and just have to solder an eye on the other end. that way your ahead of the game... till you use both ends.
MisterT
01-04-2013 08:58:29
The solder type of lugs have the solder already in them. Just slip it onto the cable and then heat it.
Welding cable will work, but it is not the same stuff as battery cable is made of.
RTR
01-04-2013 13:04:15
 Re: Need Battery Cable Lengths for Key Start Farmall 140 in reply to MisterT, 01-04-2013 08:58:29
WOW, well I wish I knew that! That is even easier than the clamp type and so much more durable and reliable!! Thanks for the tip. I have the flux and propane torch handy to do that too. How would you use flux with them since it has solder built in? Just spread some around inside the lug??
MisterT
01-04-2013 13:08:39
 Re: Need Battery Cable Lengths for Key Start Farmall 140 in reply to RTR, 01-04-2013 13:04:15
Crimping is even better than soldering, but you need some special tools to do the crimping. The best battery cable ends and lugs are made of heavy, cast copper, and are crimped on.
