Need Battery Cable Lengths for Key Start Farmall 140
RTR
I'm gonna get some new 2 GA Battery Cables for my 1975 Farmall 140 since the ones on it could stand to be a bit bigger. A new battery ground strap too, just to make things "right". I've looked in the CASE/IH parts site, but it doesn't list the particular lengths of the cables..... only the original part numbers. I'd like to get them the exact lengths per IH Specs so they don't hang out in the way and look bad. This is a "Key Start" tractor.
I'll need the Battery Ground Strap, and (2) battery cables. One from the battery to the magnetic switch (solenoid), and one from the solenoid to the starter.
THANKS FOR THE HELP Y'ALL
ya, for sure easiest. even if you take an old cable or small nylon rope and just lay it out where you want it and then get your measurement.
That would complicate things a little...But unless
you get 'face to face',the odds of getting the wrong
cables are pretty strong.Good luck!!
well thats not a laughing matter lol.
maybe just buy some welding cable and make them when you get there???
If you can find used welding cables you can make your own battery cables. That way you can make
them no longer than necessary. You can buy the soldered type lugs at most auto parts stores along with some flux. Take along a propane torch and a few tools. Hal
Actually got a pile of those things in the shop but never have used them. Always use the clamp on type if I needed to replace an end.....even though I hate those things. How do you attach the solder type lugs? What type of solder would I use to affix them.? I think all I have is the small electrical solder. We might have a roll of the larger solder (about size of 10 ga wire). What is used for those lugs?
(quoted from post at 17:53:34 01/04/13)
The solder type of lugs have the solder already in them. Just slip it onto the cable and then heat it.
Welding cable will work, but it is not the same stuff as battery cable is made of.
(quoted from post at 21:58:29 01/04/13)
WOW, well I wish I knew that! That is even easier than the clamp type and so much more durable and reliable!! Thanks for the tip. I have the flux and propane torch handy to do that too. How would you use flux with them since it has solder built in? Just spread some around inside the lug??
(quoted from post at 22:04:15 01/04/13)
Crimping is even better than soldering, but you need some special tools to do the crimping. The best battery cable ends and lugs are made of heavy, cast copper, and are crimped on.
WOW, well I wish I knew that! That is even easier than the clamp type and so much more durable and reliable!! Thanks for the tip. I have the flux and propane torch handy to do that too. [size=18:d3a875f9e1][color=red:d3a875f9e1]How would you use flux with them since it has solder built in? Just spread some around inside the lug??[/color:d3a875f9e1][/size:d3a875f9e1]
i buy my cable at the case ih dealer in about 8ft pieces at a time. i get them to crip a pos. and neg. terminal on each end. then when i need a cable i just cut it to length the + or - end and just have to solder an eye on the other end. that way your ahead of the game... till you use both ends.
(quoted from post at 03:58:54 01/05/13) i buy my cable at the case ih dealer in about 8ft pieces at a time. i get them to crip a pos. and neg. terminal on each end. then when i need a cable i just cut it to length the + or - end and just have to solder an eye on the other end. that way your ahead of the game... till you use both ends.
What do they charge for an 8 ft. peice?
