TractorLinks.com
Show Parts for Model:
Re: 1975 Farmall 140 - Only Fires When I Let off of Starter
Fixerupper
12-30-2012 18:57:55
Could be the shunt wire that bypasses the resistor when you hit the starter is broken or loose. Run a jumper wire from the positive post on the battery to the positive (+) terminal on the coil and then hit the starter. If it fires right off you've found the reason for the hard starting problem. Then you'll have to start tracing the wiring from the coil back to the ignition switch until you find it. Could be a bad switch or a wire that's vibrated off of the switch. Jim
