1466 rear hydraulic pump
Anonymous-0
I was wandering on a 1466, if the rear hydraulic pump lubes the rear end or if it's just for remotes and 3 point
Has no specific lube duties. It does dump back into rear so some splash, but all lube tubes coming into ring and pinion etc along with lube orfices and tubes in ta, speed transmission are fed from the lube circuit coming out of mcv pump.
