Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: won't start
old
12-30-2012 10:56:31
With the air cleaner hose off try to start it but as you do hold your hand over the carb air intake. You should both feel a good suction there and also when you remove your hand it should be covered with gas. If you do not have both then your compression is to low as in no suction or if no gas your carb is clogged some place. Note if you do that it also might try to start. If low suction put say a table spoon of ATF/gas mix in each cylinder and try to start it. The ATF/gas mix 50/50 will up compression and also burn like gas and may end your problems
