Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: small size alternator
12-30-2012 07:32:12
One more option is a generator converted to an alternator internally is the same look as the original Gen. Jim
12-30-2012 08:53:00
 Re: small size alternator in reply to Janicholson, 12-30-2012 07:32:12
Jim, When converting the generator to the Gener-Nator as shown in your link what is done with the original voltage regulator? If it is a pure alternator isn't the voltage regulation contained within the Gener-Nator? Do you leave the original voltage regulator installed on the tractor without any wiring hooked up or do you get creative and make it look like it is functional with the wiring in place but not functional? Just looking for your idea to replace the original generator with one of these units while still maintaining the originality appearence, Hal.
12-30-2012 09:24:50
 Re: small size alternator in reply to farmallhal, 12-30-2012 08:53:00
They are internally regulated. I would remove the regulator and strip it internally. I would solder the Bat lead to the Arm lead. The field on the Farmall Delco gen is a ground, so that could be hooked up as is with no repercussions (I have not seen the wiring diagram for these, but I suspect they are one wire based). Jim
David G
12-30-2012 08:03:42
That really looks great if someone wants the pure look. You could convert to 12V and no one would be the wiser.
