What to look for on an A
TSWolf
I am going tomorrow to look at a partially restored Farmall A that someone wants to trade me for my Ford 2N. I am not as familiar with the Farmalls as I am the Fords, so does anyone have some advice or ideas about what to look at/for on the A.
check steering wheel for play. it is a large job to rebuild the steering. everything else that i know about you can see.
It's not that bad of a job. I just finished a Farmall 140 which is pretty much the same. Just need some help when doing it. The kit for mine was $68 shipped!
I would look for a cracked block behind carburetor. Also, you'll want the manual lift, and any implements; since they are getting harder to find. Personally, an A isn't much use anymore since most tractors have the hydraulics now. Alot of people still use them in parades and such though. I would much rather have it than the 2n.
The manual lift for the Farmall A goes with the implement and is not a standard part of the tractor as the lifts are different for all the implements. So the tractor will not have a manual lift as standard equipment that goes with the tractor. There were two types of lifts manual and exhaust lift for the different implements. Loose steering is easy fixed but do check for a crack behind the carb as thats where they cracked when not enough or no Anti Freeze was in the cooling system allowing the block to freeze.
What I have found to be the most common problem is the final drive cases loose causing the bolts to break off, tear out the threads, etc etc. The result is a farmer repair by overdrilling the holes for large bolts and or welding the final drive on. Some of the final drives are broken where they mount to the trans case. Take care that they are for your tractor too. The final drives on an A and a super A are not the same. the drawbar mounting is different. The super A drawbar uses a large hex bolt and the A uses a small one. The Super A drawbar comes off just by loosening the bolts, A needs bolts removed to do so. If one has been repalaced it may be fun mounting certain implments.
I won't judge you either way on the Ford....I have a bunch of those too. I like them all. As far as it goes the 2N has 3 point and hydraulics...the A has none. Todays implements fit the 2N such as a plow or harrows that you can get at Tractor Supply or any other implment dealer...The A? Well....happy hunting. What you plan to do with the tractor should be your most important factor in making a decision.
I would love to have a BN here to ted and rake hay with.
My .02
Stumpy
As much as I dislike the 9N/2N/8N, if you are using that 3 point buy the A and keep the 2N. The 3 point and decent hydraulics are the only advantages over the A or Super A, but are important if you need them.
I do have a Ford 9N I can use for working with the 3 pt. I am just tired of fighting the unreliable 2N and want to make a change.
The As are a cultivating tractor and what is what they do best. Cultivators are a "must" implement with an A
The A is worth about half that of a 2N. As for the 2N not being reliable well it should be just as if not more then your 9N just due to age.
Things to look for well pretty much the same as any tractor. An A has No hyds at all. No 3 point. Sits taller then the N series fords do. I have and do own both or have owned both. I even have a half breed BA which is a B from the transmission forward and and A from there back
I have an A and an 8N as my little tractors. Nice to use in the barnyard as they are light enough to not tear up grass and stuff. They will do most jobs that you need without firing up a big tractor and threading it through the trees and buildings. I didn't want/need the A but took it on trade for a vehicle that set all the time anyway.
I rarely use the A. It will probably be that way for you. The cultivision was great but very few cultivate that way anymore. I sure am not taking that little bugger out to the wheat stubble with the intention of doing anything other than checking things out. It's kind of sad because I have the full set of mounted cultivators for it sitting in the shed.
I have a woods belly mower for both. I am 99% sure they are identical. I have decided that this spring I will put a belly mower on the A. Maybe then I will actually use it a bit.
That said, you can never have too many old tractors. Even if you just use it to check fence it is a fun little tractor. Just not as useable as something with 3 point and hydraulics.
I got a little lucky in CT. I purchased my A with a loader and a PTO hydraulic pump. I don't have the loader on anymore. Ill slap it on if I have a job to do.
I ended up finding someone 2 hours away with a 1940 A (I have a 41), he had a snowplow setup with manual lift, and a single bottom plow setup complete with the lift. Also threw in a belly lift for what I guess would be for a mower. All for $200.
I plow up the garden in the spring and fall, and plow snow, tow hay rides and other misc crap.
