TractorLinks.com
Show Parts for Model:
Re: Farmall M radiator
gene bender
12-29-2012 23:12:27
Mite as well remove it from the tractor then get some vinegar in as much as you can. If you turn it upside down the liquid in the tank should drain out then fill with vinegar and let it soak it will take some time but the crud should loosen up enough to shake or drain out. Mite take a while but its cheaper than a new one. I would also plug the bottom of the block and fill the engine cooling system with vinegar Sounds like you have a good project for a while.
