Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: What to look for on an A
12-29-2012 21:43:06
It's not that bad of a job. I just finished a Farmall 140 which is pretty much the same. Just need some help when doing it. The kit for mine was $68 shipped!
I would look for a cracked block behind carburetor. Also, you'll want the manual lift, and any implements; since they are getting harder to find. Personally, an A isn't much use anymore since most tractors have the hydraulics now. Alot of people still use them in parades and such though. I would much rather have it than the 2n.
gene bender
12-29-2012 23:03:53
 Re: What to look for on an A in reply to RTR, 12-29-2012 21:43:06
The manual lift for the Farmall A goes with the implement and is not a standard part of the tractor as the lifts are different for all the implements. So the tractor will not have a manual lift as standard equipment that goes with the tractor. There were two types of lifts manual and exhaust lift for the different implements. Loose steering is easy fixed but do check for a crack behind the carb as thats where they cracked when not enough or no Anti Freeze was in the cooling system allowing the block to freeze.
