Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: small size alternator
farmallhal
12-29-2012 18:09:47
The Hitachi alternator number is 14231 and was orginally used on the Nissan 1978-1980 model 620 and 720 pick-ups with the 2 liter engine. It fits nicely on a Farmall H but your application is below the hood so other alternators will work fine for you as noted earlier. Remember the Hitachi is in metrics so the fasteners won't be compatible with both the tractor and alternator. You will probably have to drill some of the mounting holes larger for bolts that fit your tractor. You will need a metric bolt for the adjustment strap as that hole will be threaded in the alternator. Good luck with your conversion, Hal.
Copyright © 1997-2015 Yesterday's Tractor Co.
