TractorLinks.com
Show Parts for Model:
Re: gas ih 560 carb keeps freezing up
Stuart
12-29-2012 17:44:56
Your so far off its not even funny.
old
12-29-2012 17:50:20
 Re: gas ih 560 carb keeps freezing up in reply to Stuart, 12-29-2012 17:44:56
BULL stupid
Stuart
12-29-2012 17:53:40
 Re: gas ih 560 carb keeps freezing up in reply to old, 12-29-2012 17:50:20
Out of all the old gas tractors I have, none have the carbs ice up on them.
John G. Hasler
12-30-2012 13:50:01
 Re: gas ih 560 carb keeps freezing up in reply to Stuart, 12-29-2012 17:53:40
My 544 never ices. I"ve seen ice in my 8N once. My 560 almost always gets ice on it. Doesn"t stop it running, though.
rustred
12-29-2012 18:22:18
you must not be running them when its below freezing. i have seen carbs ice up since i was 7 yrs. old. perfectly normal.
old
12-29-2012 18:14:54
You have either been lucky of you just do not stop to look. It is a fact of life and how a carb works that causes the manifold to get real cool. Ya it does not happen all the time and few people ever see it happen. Start a tractor then go over and hold your hand close to the top of the carb where it bolts to the manifold and you will find that it is very cool and if weather conditions are right if will frost up. On many engines you will never notice a problem but it can be it things so happen to be just right. That is why on the older cars and trucks they had the warm air tube gong into the air cleaner to keep the carb warm and help it from frosting up. Another fact the Indians of the South west used evaporation of wet hides to make cooling systems for there homes and some times even ice
Stuart
12-29-2012 22:21:05
 Re: gas ih 560 carb keeps freezing up in reply to old, 12-29-2012 18:14:54
I never said it doesnt get cold, just never had one freeze up. You must of missed that point.
peter29
12-29-2012 17:59:31
it is the first year for this problem never happened before carb has not been touched in years. the tractor plowed snow last year with no problems I dont get it.
todd Hamilton
12-29-2012 19:14:16
 Re: gas ih 560 carb keeps freezing up in reply to peter29, 12-29-2012 17:59:31
Possibly different fuel blend for your region of the country. My old case SC did the same thing. Old and all others are correct, normal. Find a way to warm the manifold. Airplane engines have adjustable manifold heat for this same issue.
old
12-29-2012 18:18:43
Caused by weather conditions and normal carb function. If things are right yes it can cause problems. If it is cold and humid where you are yes it can cause a problem and then the next year not a problem. If you have a way to cover that side of the engine with a trap or sheet of metal etc you will find holding the engine heat in will stop that problem. Every year I see posts like this and every year people are told the same thing. Been on here now for over 10 years and I have said the same thing year after year and others have agreed with what I have said time and time again
