Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: gas ih 560 carb keeps freezing up
[Show Entire Topic]  [Return to Forum]
old
12-29-2012 17:15:47
209.86.226.19
ALL carbs ice up and it is part of how they work. If the did not your engine would not run it is due to the atomizing of the fuel that in turn cause the manifold area to get cold and it is just normal operation of a carb and you old cars and trucks do the same thing. If it bugs you don't look at it. Yes some time for a bit the engine will not run as well but it should clear up once the engine warms up more. Also opening up the main jet a tad bit helps. So as I said it is normal and nothing to worry about
[Reply]   [No Email]
Stuart
12-29-2012 17:44:56
166.181.3.17
 Re: gas ih 560 carb keeps freezing up in reply to old, 12-29-2012 17:15:47
Your so far off its not even funny.
[Reply]  [No Email]
old
12-29-2012 17:50:20
209.86.226.19
 Re: gas ih 560 carb keeps freezing up in reply to Stuart, 12-29-2012 17:44:56
BULL stupid
[Reply]  [No Email]
Stuart
12-29-2012 17:53:40
166.181.3.102
 Re: gas ih 560 carb keeps freezing up in reply to old, 12-29-2012 17:50:20
Out of all the old gas tractors I have, none have the carbs ice up on them.
[Reply]  [No Email]
John G. Hasler
12-30-2012 13:50:01
174.124.11.155
 Re: gas ih 560 carb keeps freezing up in reply to Stuart, 12-29-2012 17:53:40
My 544 never ices. I"ve seen ice in my 8N once. My 560 almost always gets ice on it. Doesn"t stop it running, though.
[Reply]  [No Email]
rustred
12-29-2012 18:22:18
184.151.222.114
you must not be running them when its below freezing. i have seen carbs ice up since i was 7 yrs. old. perfectly normal.
[Reply]  [No Email]
old
12-29-2012 18:14:54
209.86.226.19
You have either been lucky of you just do not stop to look. It is a fact of life and how a carb works that causes the manifold to get real cool. Ya it does not happen all the time and few people ever see it happen. Start a tractor then go over and hold your hand close to the top of the carb where it bolts to the manifold and you will find that it is very cool and if weather conditions are right if will frost up. On many engines you will never notice a problem but it can be it things so happen to be just right. That is why on the older cars and trucks they had the warm air tube gong into the air cleaner to keep the carb warm and help it from frosting up. Another fact the Indians of the South west used evaporation of wet hides to make cooling systems for there homes and some times even ice
[Reply]  [No Email]
Stuart
12-29-2012 22:21:05
166.181.3.30
 Re: gas ih 560 carb keeps freezing up in reply to old, 12-29-2012 18:14:54
I never said it doesnt get cold, just never had one freeze up. You must of missed that point.
[Reply]  [No Email]
peter29
12-29-2012 17:59:31
74.37.239.118
it is the first year for this problem never happened before carb has not been touched in years. the tractor plowed snow last year with no problems I dont get it.
[Reply]  [No Email]
todd Hamilton
12-29-2012 19:14:16
174.254.145.78
 Re: gas ih 560 carb keeps freezing up in reply to peter29, 12-29-2012 17:59:31
Possibly different fuel blend for your region of the country. My old case SC did the same thing. Old and all others are correct, normal. Find a way to warm the manifold. Airplane engines have adjustable manifold heat for this same issue.
[Reply]  [No Email]
old
12-29-2012 18:18:43
209.86.226.19
Caused by weather conditions and normal carb function. If things are right yes it can cause problems. If it is cold and humid where you are yes it can cause a problem and then the next year not a problem. If you have a way to cover that side of the engine with a trap or sheet of metal etc you will find holding the engine heat in will stop that problem. Every year I see posts like this and every year people are told the same thing. Been on here now for over 10 years and I have said the same thing year after year and others have agreed with what I have said time and time again
[Reply]  [No Email]
peter29
12-29-2012 17:22:42
74.37.239.118
stalled out wont run unless you pull choke out after it dies. once you wait about 15 min. it will run for about 10 then it starts all over again.
[Reply]  [No Email]
old
12-29-2012 17:53:42
209.86.226.19
 Re: gas ih 560 carb keeps freezing up in reply to peter29, 12-29-2012 17:22:42
Open the main jet up just a little bit till you find the spot that works. When it is cold out some times you need a richer mix to run well. You can also make a side cover to help hold in heat. Some people make a cover from foil so as to help hold more heat in the area. That is why on the older cars they had a tube that went from the exhaust manifold into the air cleaner intake to pull the warm air into the carb so that carb icing did not happen but on a tractor doing that would not be easy
[Reply]  [No Email]
GordoSD
12-30-2012 07:40:10
216.106.244.233
 Re: gas ih 560 carb keeps freezing up in reply to old, 12-29-2012 17:53:42
Engine runs cooler on rich mixture, hotter on lean.
[Reply]  [No Email]
old
12-30-2012 10:37:55
209.86.226.27
 Re: gas ih 560 carb keeps freezing up in reply to GordoSD, 12-30-2012 07:40:10
Ya but in the winter an engine runs better when set rich so whats your point or just being your normal but head again
[Reply]  [No Email]
CNKS
12-30-2012 14:14:09
216.144.104.128
 Re: gas ih 560 carb keeps freezing up in reply to old, 12-30-2012 10:37:55
Old and Gordo -- You can richen the mixture because cold air is heavier than warm air, thus more air allows the mixture to be richened in cold weather. If you heat the air then you lose the advantage of the cold air--but if it is necessary to get rid of the frost, there is no choice.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
