spray truck bed liner on steering wheel? jbp?
A while back I seen a post (link below) in which jpb said hes had good luck re coating steering wheels with spray truck bed liner.
I'd like to try this, but would like to know the brand and retailer where this was purchased?
The local Home Depot had several different ones.
link
I'm the one did it, used the O'Reilly's brand in a blue can "Dupli=Color". I sprayed three or four layers, letting it dry a few days each layer then sanding the rough edges off. I like it a whole lot, it really seals and conceals the cracks, prevents pieces falling off, has a really good gripy feel non-slip. Only thing, it is rough, and where you sand it will be slightly different sanded-look compared to the rest black-look. You might try it a few times on a piece of dowel rod to see what it looks like. But I like it a lot.
David, I used spray can truck bed liner from the local WalMart. The steering wheels were on an H and Cub tractor that showed very little wear, they were getting my hands black every time I drove them. It stopped that problem while giving them a slightly rough surface for better gripping. So far I am very satisfied with the outcome.
Joe
