Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Farmall B valve timming
pete 23
12-28-2012 10:01:34
Gears are always marked so they will only align one way. In the case of single punch marks, if one gear is marked on the tooth and the mating gear is marked between the teeth then you align single to single. With double marks that are marked one on each tooth itself then the single mark on other gear would go between them.
gene bender
12-28-2012 10:22:40
 Re: Farmall B valve timming in reply to pete 23, 12-28-2012 10:01:34
Not on the engines for the A,B and C. Single NEVER goes between the two. Mite be so on another engine but not on those models. Iv done too many of them and the I@T manual even shows them single on single and double on double.
pete 23
12-28-2012 10:59:50
 Re: Farmall B valve timming in reply to gene bender, 12-28-2012 10:22:40
But the single would not match like I said. Can't have tooth on tooth, and if it went between it would not line up.
