Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Farmall B valve timming
[Return to Forum]
jnewark
12-28-2012 07:05:48
167.21.254.12
greetings, I am rebuilding a B, the camshaft gear has 2 punch marks on one side and 1 punch mark on the other, the crank gear has 1 punch mark, the distributor gear has 2 punch marks, am I correct in assuming the 2 punch marks aling and the single punch marks aling, the shop manual is not real clear.. thanks in advance
jack
[Reply]   [No Email]
gene bender
12-29-2012 04:51:15
67.55.227.74
 Re: Farmall B valve timming in reply to jnewark, 12-28-2012 07:05:48
It seems like there are lots of opinions on this subject but without a doubt not much expereince or there wouldnt be different opinions. Glad to see the pic from I@T as that should set everyone straight.
[Reply]  [No Email]
Bill Hires
12-28-2012 15:50:22
207.119.231.182
Copied from I & T Manual IH -8
[Reply]  [No Email]
pete 23
12-28-2012 10:01:34
74.32.229.189
Gears are always marked so they will only align one way. In the case of single punch marks, if one gear is marked on the tooth and the mating gear is marked between the teeth then you align single to single. With double marks that are marked one on each tooth itself then the single mark on other gear would go between them.
[Reply]  [No Email]
gene bender
12-28-2012 10:22:40
67.55.227.74
 Re: Farmall B valve timming in reply to pete 23, 12-28-2012 10:01:34
Not on the engines for the A,B and C. Single NEVER goes between the two. Mite be so on another engine but not on those models. Iv done too many of them and the I@T manual even shows them single on single and double on double.
[Reply]  [No Email]
pete 23
12-28-2012 10:59:50
74.32.229.189
 Re: Farmall B valve timming in reply to gene bender, 12-28-2012 10:22:40
But the single would not match like I said. Can't have tooth on tooth, and if it went between it would not line up.
[Reply]  [No Email]
gene bender
12-28-2012 08:49:42
67.55.227.74
You are correct the single marks align with each other and the same with the double marks. If your mag is good it will fire on the first turn providing the carb is also up to snuff. Ive done a bunch of them and they will start on the first rev.
[Reply]  [No Email]
jnewark
12-28-2012 09:51:47
167.21.254.12
 Re: Farmall B valve timming in reply to gene bender, 12-28-2012 08:49:42
gene would you be related to the benders in Delaware. the tractor belonged to clayton Bender
jack
[Reply]  [No Email]
gene bender
12-28-2012 10:24:48
67.55.227.74
 Re: Farmall B valve timming in reply to jnewark, 12-28-2012 09:51:47
I know a Clayton but he lives in Ariz. If i have kin in Del dont know any of them
[Reply]  [No Email]
El Toro
12-28-2012 07:38:49
108.3.143.30
To align the cam & Crankshaft gears: Mesh the single punch mark on the camgear with the double punch mark on the crankshaft gear.
Mesh the double punch mark on the cam gear with the double punch mark on the distrubutor or mag-governor drive gear. Hal
[Reply]  [No Email]
rustred
12-28-2012 07:22:19
184.151.222.114
the single punch mark always goes between the double marks... not the doubles mating with each other and singles together as it appears you are inquiring about.
[Reply]  [No Email]
gene bender
12-29-2012 04:47:21
67.55.227.74
 Re: Farmall B valve timming in reply to rustred, 12-28-2012 07:22:19
What engines have you done that way. Or is that some tale you were told.
[Reply]  [No Email]
teddy52food
12-28-2012 07:15:42
184.94.175.179
If I remember right, the single crankgear mark fits between the 2 on the cam gear, then the single on the cam gear fits between the 2 on the gov gear. Someone correct me if this is wrong. When I put them together, I also look at where the cam lobes are when #1 piston is at TDC.
[Reply]  [No Email]
gene bender
12-28-2012 08:52:39
67.55.227.74
 Re: Farmall B valve timming in reply to teddy52food, 12-28-2012 07:15:42
You need to be corrected. Even being off a tooth can make for hard starts. Had a hand cranker started bad and that was the problem after taking off the front cover.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
