| Farmall & IHC Tractors Discussion Forum |
Topic: Checking transmission fluid on 1951 Farmall C
[Return to Forum]
| Author |
[Modern View]
| vet119
12-28-2012 06:08:02
67.142.178.25
I cannot find info on checking the transmission fluid on my 1951 Farmall C. I think it is one of the plugs on the left side of the tractor? I have an owners manual but, it does not tell you how to check. |
| Dean Olson
12-28-2012 06:52:30
98.196.66.64
Re: Checking transmission fluid on 1951 Farmall C in reply to vet119, 12-28-2012 06:08:02
| The plug your looking for is a 1/4" plug on the right side of the trans housing. It's at the back corner close to the same level as the PTO shaft and axle. The 1" fill plug is on the top deck next to the shifter. It takes a 1/2 ratchet to unscrew. You fill the trans until it comes out the 1/4" plug. The drain plug is at the center/bottom of the trans housing. Unscrew the drain plug and get a sample of your existing fluid. You may get a shot of water then oil. If it's clean top it off. Not clean will look milky, brown, goopy crap that may not drain at all. You may need to poke a through the crud to get it to drain. Last one I did took several days to drain and stop dripping. If it's bad I drain it and dump 5 gallons of diesel in. Then go for a easy no load spin around the yard and let it sit for a day. Drive it around again and then drain and refill. Takes about 5 gallons, I use 85w-140 gear oil. Book calls for straight 80w-90. |
| gene bender
12-28-2012 08:55:15
67.55.227.74
Re: Checking transmission fluid on 1951 Farmall C in reply to Dean Olson, 12-28-2012 06:52:30
| I do the same after all the yrs a good flushing and new lube sure cant hurt anything. |
| vet119
12-28-2012 07:02:43
67.142.178.25
| gene bender
12-28-2012 06:20:03
67.55.227.74
| That plug is where you check the level its supposed to be full at the plug. Mite want to drain and flush then fill with new. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
