F 20 carb HELP!!!!!
I have an f 20 with a Zenith carb. Numbers on it are 35539 8099A. Im trying to find a carb kit but nothing matches those numbers. Can anyone tell me what kit i need or what that carb mite be off of? thanks.
any carb kit for a zenith K5 carb will work. there is only 1 'generic' carb kit available now. more than likely it will come from A&I
call Alderson Tractor here in Iowa, they have them in stock
www.aldersontractor.com
(quoted from post at 20:49:06 12/27/12) any carb kit for a zenith K5 carb will work. there is only 1 'generic' carb kit available now. more than likely it will come from A&I
If yours is stock its a K5 Carb, looks like this
Make sure you get a F-20 kit, not a F-30 kit. The jets are different.
Rice equipment has both.
F-Dean, I am not sure, which is why I am asking, but I thought the only difference between the F-20 K5 and the F-30 K5 was the venturi. I thought the rest was the same. Am I mistaken?
(quoted from post at 16:11:37 12/28/12) F-Dean, I am not sure, which is why I am asking, but I thought the only difference between the F-20 K5 and the F-30 K5 was the venturi. I thought the rest was the same. Am I mistaken?
without double checking the parts book i think the venturi, main jet, and emulsion tube is different
