TractorLinks.com
Show Parts for Model:
Re: 584 hydraulics problem HELP
ben brown
12-27-2012 18:23:32
where the filter canister fits up there's a o-ring behind it my bet is you pinched it and now have a air leak take it off make sure the o-ring is in the grove and is not cut replace canister see if that don't work up under the finder where the filter is located it real easy to cut the o-ring also don't let canister turn as you are tightening it up as that well also case you problems as sometime the o-ring well move out of the grove
warren woodrow
12-28-2012 09:30:58
 Re: 584 hydraulics problem HELP in reply to ben brown, 12-27-2012 18:23:32
Thanks -I have a new gasket and have toof filter off and on 3 times trying to get a seal. Gonn apull again and check to see if maybe something in groove keeping it from sealing . Appreciate any and all input.
