Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 51 super c front wheels
kennell
12-27-2012 16:34:03
Both my C and SC had 15 inch wheels. Kent
Pete Cormier
12-27-2012 18:21:58
 Re: 51 super c front wheels in reply to kennell, 12-27-2012 16:34:03
i needed new front wheels and just now found out that new 19'' wheels are blanks and that i have to remove the old tabs and weld them onto the new wheels... thanks kent
504
12-27-2012 20:31:13
 Re: 51 super c front wheels in reply to Pete Cormier, 12-27-2012 18:21:58
I don t think there is enough clearance for 19" tires.
Old-F20
12-27-2012 20:34:23
 Re: 51 super c front wheels in reply to 504, 12-27-2012 20:31:13
it would have to be a wide front wouldnt it??
i thought the same thing
DeltaRed
12-27-2012 20:37:38
 Re: 51 super c front wheels in reply to Old-F20, 12-27-2012 20:34:23
My wide front SC hhas 15" fronts,as is all SCs I have ever seen.Sounds like you have wheels for a cane/hi crop.
Pete Cormier
12-28-2012 15:43:53
 Re: 51 super c front wheels in reply to DeltaRed, 12-27-2012 20:37:38
yep, it is a wide front. it does have 19'' wheels and there is clearance. it must have been used on the local cane farms.the front is 2'' higher than if it had 15'' wheels. i'll have to return the 15'' wheels i ordered. after blasting and paint the old 19'' wheels look a lot better. thanks for all the input.
504
12-28-2012 20:34:54
 Re: 51 super c front wheels in reply to Pete Cormier, 12-28-2012 15:43:53
All row crop narrow around here, I never thought a bought a wide front. I replaced a rear rim on my SC and it came as a blank. I ground the rivets off from the inside and left the head in the bracket, then just welded the bracket to the rim. You have to look close to know it is not riveted on.
