Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Bearing noise 484 IH
[Return to Forum]
Martin Reece
12-27-2012 13:22:29
69.49.39.52
Good day all,
I was snow blowing this morning with my 484 IH. I noticed a loud grinding noise like a bad bearing inside the rear end at the pto shaft. It would only happen when the snowblower was lowered all the way down. If I raised it so the pto shaft was straight it would go away. I thought it was the snowblower at first, but it definitely was coming from inside the rear end.. Can the pto shaft bearings be replaced from the back of the tractor or does it need to be split. Any info would be appreciated.
Thanks Martin
[Reply]   [No Email]
martin reece
12-28-2012 03:41:16
69.49.39.52
 Re: Bearing noise 484 IH in reply to Martin Reece, 12-27-2012 13:22:29
You guys are great!
Thanks , Martin
[Reply]  [No Email]
9598Farmallred
12-27-2012 20:38:57
64.194.68.234
Quoting Removed, click Modern View to see Martin, yes you can replace the bearings without splitting tractor all you need to do is remove rockshaft cover there is a snap ring behind the gear you will need to remove, also the seal & rear brg. retainer, check the inner brg. bore in the rear end housing as these brg,s would fail and eat the bearing bore away this can also be repaired fairly easily by a machine shop without further disassembly. I hope this helps Andy.
[Reply]  [No Email]
jimb2
12-27-2012 18:39:16
174.114.182.155
Hi Martin,
I looked in my I&T manual and it does not give any instructions about replacing 540 RPM PTO bearing only how to replace the complete shaft. IIRC neighbour changed PTO bearing on his 4210 from the rear.
Before tearing it apart, I would check the bearing by using an old broom handle held against the bearing cover and the other end against your ear and listen for the squealing noise. BECAREFUL NOT to get tangled up in the PTO.
JimB
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
