TractorLinks.com
Show Parts for Model:
Re: cold temps out side and my H wants to stall
Russ600
12-27-2012 11:42:07
Hi.
If you think the carb is icing which what I think the problem is. Try bring some warm air into the air cleaner. This should pretty easy as you have said you have a heater houser on your tractor. Take piece of flexable exhaust pipe or hose, put one end on the air cleaner inlet and put the out end under the heat houser along side to engine. This will warm up the air going into the carb. I have done this one other engines that had carb icing issues. Good Luck
Cheers
Russ
