TractorLinks.com
Show Parts for Model:
Re: 584 auxiliary valve
warren woodrow
12-27-2012 10:19:06
Thanks . I went and looked today and found I still have a tiny leak from filter canister as it had dripped a small amount on ground overnight. I am hoping I will solve my aeration problem if I can ever get the canister to seal correctly to the gasket. Tried not tightening too tight , then tried tightening a little more[got some better] hate to tighten more so I may pull it off and try again. Those darn things should be easy as the canister is in the groove . Thanks for all the input . This has been a long haul for a guy like myself with little time . Started out just changing the o-ring on pto idler shaft but when I pulled it out needle bearings went everywhere due to ends of caged needle bearing having worn off . 10 minute project is now 3 weeks later but almost done after having to pull lift cover and......... on and on.
