Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Farmall H question
[Show Entire Topic]  [Return to Forum]
farmerwannabe
12-26-2012 17:33:00
184.21.162.111
Thanks Old. I used this quite a bit to clean up a barn and field. It started this problem when I was driving it to the new farm we bought, about a 10 mile ride in relatively warm weather at the time. It started pretty quickly into the drive and had done so ever since, about 2 months now.
[Reply]   [No Email]
old
12-26-2012 18:18:22
209.86.226.34
 Re: Farmall H question in reply to farmerwannabe, 12-26-2012 17:33:00
Been a while since I have messed with any of the Hs I have so not 100% sure on this. If I remember right the main jet adjustment is low on the carb and it can be removed in 3 pieces or as a whole. Remove it as a whole then check it out and make sure it is not clogged up and also make sure you get a good flow of fuel out of it
[Reply]  [No Email]
farmerwannabe
12-26-2012 18:55:25
184.21.162.111
 Re: Farmall H question in reply to old, 12-26-2012 18:18:22
Hi Old. You answered a lot of questions about the Allis B and WD45 I messed with through the years. I'm not real familiar with IH's. I'll check the flow through the fuel lines first, but if that checks out, is there a filter in the carb at all?
[Reply]  [No Email]
old
12-26-2012 19:08:54
209.86.226.34
 Re: Farmall H question in reply to farmerwannabe, 12-26-2012 18:55:25
I do not remember if there is a screen in the carb inlet or not been to long since I have been in one of those carbs. I can say if you try this you may save your self some time. Simply pull the carb drain plug out of the bottom of the carb. If you get a good steady flow of gas there for 3-5 minutes then you lines are not clogged up. Catch the gas so you can see if it has dirt/rust/water in it. If it has an odd miss try cleaning the plugs and or even try to move the plugs around to see if the miss goes with a plug
[Reply]  [No Email]
farmerwannabe
12-28-2012 11:20:13
184.21.162.111
 Re: Farmall H question in reply to old, 12-26-2012 19:08:54
Will give it a try Old. Thanks!
[Reply]  [No Email]
old
12-28-2012 11:57:36
209.86.226.54
 Re: Farmall H question in reply to farmerwannabe, 12-28-2012 11:20:13
You never did answer the question about the hyd cylinders and if they where 2 or 3 stage or just single stage
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
