| Farmall & IHC Tractors Discussion Forum |
Topic: Re: 584 auxiliary valve
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| warrenwoodrow
12-26-2012 13:21:43
108.131.127.113
Thanks a million. I got it going today but front end loader is jerking / hesitating. I checked the filter and it was clean but I have an excessive amount of air in the system as evidenced by air bubbles in fluid. I have worked all cylinders through complete cycle/range of motion but still air and hiccup. Do you have any ideas and is there a better way to get air out. |
| Jim Naden
12-26-2012 13:39:37
12.74.49.109
Re: 584 auxiliary valve in reply to warrenwoodrow, 12-26-2012 13:21:43
| Quoting Removed, click Modern View to see
Does the steering act aerated also?
Is the system aerated as soon as you start the tractor or does it aerate after running a while?
Jim N. |
| warren woodrow
12-26-2012 22:04:12
108.131.127.113
Re: 584 auxiliary valve in reply to Jim Naden, 12-26-2012 13:39:37
| One more thing- I had changed the filter and checked the screen and noticed a tiny drip when I turned off the tractor. I took off and reinstalled filter and made leak stop. I suppose I may have been drawing air . I noticed when I bought new filter that there were two o-rings in package. My old filter only used one on the bolt in a groove. I checked the drawings on internet and they only show the one o-ring also. I did of course use the new gasket. |
| waren woodrow
12-26-2012 20:54:33
108.131.127.113
| The level check acts strange also.I put 9 gallons in and checked and it seemed to be at right level on stick . Now I crank and run for 3 minutes and shut off as manual says ans sometimes it will not mark the dipstick [ I guess this has something to do with air. I have unscrewed and check breather and it is clear . |
| Jim Naden
12-27-2012 02:22:14
12.74.49.161
Re: 584 auxiliary valve in reply to waren woodrow, 12-26-2012 20:54:33
The dipstick tube isn't vented well. Always pull the dipstick, wipe and recheck. This lets the true oil level come up in the dipstick tube to get an accurate level reading. |
| warren woodrow
12-27-2012 10:19:06
108.131.127.113
Re: 584 auxiliary valve in reply to Jim Naden, 12-27-2012 02:22:14
| Thanks . I went and looked today and found I still have a tiny leak from filter canister as it had dripped a small amount on ground overnight. I am hoping I will solve my aeration problem if I can ever get the canister to seal correctly to the gasket. Tried not tightening too tight , then tried tightening a little more[got some better] hate to tighten more so I may pull it off and try again. Those darn things should be easy as the canister is in the groove . Thanks for all the input . This has been a long haul for a guy like myself with little time . Started out just changing the o-ring on pto idler shaft but when I pulled it out needle bearings went everywhere due to ends of caged needle bearing having worn off . 10 minute project is now 3 weeks later but almost done after having to pull lift cover and......... on and on. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
