TractorLinks.com
Show Parts for Model:
Re: Farmall Smta won't start
sflem849
12-25-2012 14:11:49
A volt meter while cranking would be the quick and dirty way around playin with battery acid.
Also, a good key to having too low of voltage is thwt the tractor starts when you let off the starter.
El Toro
12-25-2012 18:33:54
 Re: Farmall Smta won't start in reply to sflem849, 12-25-2012 14:11:49
Low voltage won't tell you what what's causing the problem. Specific gravity will tell you quickly if you have weak or dead cell. Hal
sflem849
12-25-2012 19:02:13
 Re: Farmall Smta won't start in reply to El Toro, 12-25-2012 18:33:54
But it sure is a lot quicker and easier. Not to mention you are not playing with a very strong acid. It will also tell you if you need to look into the battery using your methods.
El Toro
12-26-2012 03:59:03
 Re: Farmall Smta won't start in reply to sflem849, 12-25-2012 19:02:13
I'll stick with my method. I don't thnk you've been around batteries very much. We did a lot of cold starting on military vehicles. Some had 8 large batteries. Hal
