TractorLinks.com
Show Parts for Model:
Re: Farmall H question
The Red
12-25-2012 12:54:04
Open the high speed mixture screw a half turn.
farmerwannabe
12-25-2012 19:21:59
 Re: Farmall H question in reply to The Red, 12-25-2012 12:54:04
Hi guys. Thanks for the advice. Tomorrow after work I will check the fuel flow and then go from there. It ran perfectly up until recently, so I am hoping this is something relatively simple.
old
12-25-2012 19:30:06
 Re: Farmall H question in reply to farmerwannabe, 12-25-2012 19:21:59
Common in winter to have to richen up the fuel a tad bit then in the summer back it back off some due to the heat and cold
farmerwannabe
12-26-2012 17:33:00
 Re: Farmall H question in reply to old, 12-25-2012 19:30:06
Thanks Old. I used this quite a bit to clean up a barn and field. It started this problem when I was driving it to the new farm we bought, about a 10 mile ride in relatively warm weather at the time. It started pretty quickly into the drive and had done so ever since, about 2 months now.
old
12-26-2012 18:18:22
 Re: Farmall H question in reply to farmerwannabe, 12-26-2012 17:33:00
Been a while since I have messed with any of the Hs I have so not 100% sure on this. If I remember right the main jet adjustment is low on the carb and it can be removed in 3 pieces or as a whole. Remove it as a whole then check it out and make sure it is not clogged up and also make sure you get a good flow of fuel out of it
farmerwannabe
12-26-2012 18:55:25
 Re: Farmall H question in reply to old, 12-26-2012 18:18:22
Hi Old. You answered a lot of questions about the Allis B and WD45 I messed with through the years. I'm not real familiar with IH's. I'll check the flow through the fuel lines first, but if that checks out, is there a filter in the carb at all?
old
12-26-2012 19:08:54
 Re: Farmall H question in reply to farmerwannabe, 12-26-2012 18:55:25
I do not remember if there is a screen in the carb inlet or not been to long since I have been in one of those carbs. I can say if you try this you may save your self some time. Simply pull the carb drain plug out of the bottom of the carb. If you get a good steady flow of gas there for 3-5 minutes then you lines are not clogged up. Catch the gas so you can see if it has dirt/rust/water in it. If it has an odd miss try cleaning the plugs and or even try to move the plugs around to see if the miss goes with a plug
farmerwannabe
12-28-2012 11:20:13
 Re: Farmall H question in reply to old, 12-26-2012 19:08:54
Will give it a try Old. Thanks!
old
12-28-2012 11:57:36
 Re: Farmall H question in reply to farmerwannabe, 12-28-2012 11:20:13
You never did answer the question about the hyd cylinders and if they where 2 or 3 stage or just single stage
