| Farmall & IHC Tractors Discussion Forum |
Topic: Re: 656 stuck in gear
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| The tractor vet
12-24-2012 06:55:37
75.24.4.81
Yep they are at that and in MHOP they are a real pain sometimes ya can cheat with shim washers and the shifters all snugged together and installing a new pin on the shifter rod and i have had the machine shop make a little larger pin and redrill the hole thru the shaft for the larger pin to take out some slop. So if the shaft pin went between the 1st and Reverse and 2nd and 3rd shift lever shimming will stop that If it sheared the pin then a new shifter pin will fix that . And if one of the headed pin clippys fell off and the pin came out a new pin and clippy will fix that. |
| John G. Hasler
12-24-2012 08:58:03
174.124.11.155
Re: 656 stuck in gear in reply to The tractor vet, 12-24-2012 06:55:37
| The 656 has the same linkage as the 544, does it not? I was able to rebuild mine without buying any parts. I made new "gates" (the notched plates in the selector mechanism) with a Dremel and drill press and drilled out the linkages and installed oversize pins. Note that the pins in the final link are supposed to be welded in. If these welds are broken you"ll have lots of slop. You also want to make sure the neutral detent is working. On mine the ball has worn a groove in the selector shaft, rendering the detent useless. Someday I"ll weld up the groove and turn it down on the lathe. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
