TractorLinks.com
Show Parts for Model:
Re: Farmall. 300
Janicholson
12-21-2012 20:05:49
No nylon to my knowledge. If it was wet snow at about the freezing point, the throttle plate could have iced up and stuck. Does wide open mean over revving, or just not going to idle. Over revving has the engine turning beyond full throttle speeds, Not good.
A stuck throttle or linkage off of the throttle lever getting stuck at full throttle is different.
If that were the case, it would operate fast, but no faster than normal full throttle. it would be able to sense loads and change throttle position but stay at the normal high speed.
If runaway speed, the throttle either stuck in the carb (shaft or loose plate getting jammed), or the tab in the linkage at the inside of the governor tube to carb fitting broke off. Jim
DeltaRed
12-21-2012 20:30:28
 Re: Farmall. 300 in reply to Janicholson, 12-21-2012 20:05:49
Jim,Some of the newer carb kits now have a nylon/plastic piece on the throttle shaft where it connects to the governor.
riverbend
12-22-2012 07:52:12
 Re: Farmall. 300 in reply to DeltaRed, 12-21-2012 20:30:28
Newer ? I haven't seen one in 20 years.
Greg
Janicholson
12-21-2012 20:44:17
That is not good!!! Jim
