Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: No valve seals found in IH 404 prior to rebuild.
12-21-2012 15:59:26
Will they work without machining the heads? Any part # I can order with? Thank you so much!
pete 23
12-21-2012 18:38:50
 Re: No valve seals found in IH 404 prior to rebuild. in reply to RandyDowdy, 12-21-2012 15:59:26
The guides will most likely have to be machined to get a flat on top and maybe reduce outside diameter. Any automotive machine shop should be able to come up with the specs and a good seal. I no longer have that information myself. I did a lot of machining valve guides back in the day as they say. It is real simple. That and the height of the machined guide is what is important.
12-21-2012 20:27:52
 Re: No valve seals found in IH 404 prior to rebuild. in reply to pete 23, 12-21-2012 18:38:50
Thank you.
