TractorLinks.com
Show Parts for Model:
Re: No valve seals found in IH 404 prior to rebuild.
pete 23
12-21-2012 15:48:57
If it was mine I would put perfect circle seals or equivelent on it. A worn rocker arm and shaft assembly throws a lot more oil over the top of them valves than it did when it was new. You will see it smoke at start up if it needs seals but does not have them. Umbrella was a economy version for manufactures to get by with. If you look at the Neuss, (German) engines you will see a good seal on all valves.
RandyDowdy
12-21-2012 15:59:26
 Re: No valve seals found in IH 404 prior to rebuild. in reply to pete 23, 12-21-2012 15:48:57
Will they work without machining the heads? Any part # I can order with? Thank you so much!
pete 23
12-21-2012 18:38:50
 Re: No valve seals found in IH 404 prior to rebuild. in reply to RandyDowdy, 12-21-2012 15:59:26
The guides will most likely have to be machined to get a flat on top and maybe reduce outside diameter. Any automotive machine shop should be able to come up with the specs and a good seal. I no longer have that information myself. I did a lot of machining valve guides back in the day as they say. It is real simple. That and the height of the machined guide is what is important.
RandyDowdy
12-21-2012 20:27:52
 Re: No valve seals found in IH 404 prior to rebuild. in reply to pete 23, 12-21-2012 18:38:50
Thank you.
RandyDowdy
12-21-2012 15:53:33
This is the information I am seeking. Where would they be bought ? Thank you so much!
