Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Replacing oil seal on Farmall C axel ?
Dennis K (WA)
12-21-2012 10:05:15
Hi Paul
Like others have said, it needs to be removed as an assembly but first you need to remove capscrews holding retainer #19 in your picture.
The bull gear stays in the main case,
I found it easier to reinstall by filing a chamfer on the end of the splines where the shaft reenters the bull gear.
You may be able to remove the retainer bolts by removing the PTO assembly but reassembling will be a challenge because the bull gear will drop a bit once the shaft is removed. I removed the top cover when I did mine. I kind of wanted to see what else was going on in there anyway.
Have fun
Dennis
Paul Shuler
12-21-2012 10:15:29
 Re: Replacing oil seal on Farmall C axel ? in reply to Dennis K (WA), 12-21-2012 10:05:15
When you lift the deck off is that a two man job or is there anyway maybe to use my engine hoist on it you think. I have a big stout 20 year old son but its hard for us to get together cause he works so much.
Paul Shuler
12-21-2012 10:12:02
Thanks so much guys for the advise. I will update with a post when I get it all done. Hope to tear into it in January sometime.
