Farmall B weights
Dave H (MI)
I have two sets of rear weights for this tractor I was going to go ahead and put on. It moves a lot of loaded wagons around and could use the traction. Looks like I need some big carriage bolts for this. would anyone happen to know the correct size and length for mounting two sets of rears on a B?
When I did my BA I used tread rod I think 3/4 inch to do the job so I could do one set or 2 sets and be able to drop one set off and not worry about the other set unless I removes another nut. I hate to have to worry about something falling off and hitting my toes. Broke then once and that was 10 times to many
You can put one set on the inside of the center section then one set on the outside that way you wont have them sticking out too far.
