460 - 606 interchangeability
Gibby
I see that both the Farmall 460 and then Internation al 606 use the C221 engine. Any other parts inter changeable? Hydraulic pumps, etc?
Some of the parts will interchange, its hit & miss everywhere, front wheels & hubs with exceptions, engine would probably work, radiator & sheet metal not, some rear trans frame gears, not wide front axle or rear axles or wheels, hydraulics similiar, main pump will work but not steering pump because Farmall 460/560 has a high pressure relief in pump, clutch & ta some interchange, Farmall was row crop & earlier design, I606 is International + later design, lower slung like 300 Utility, not as row crop adaptable. Steering entirely different.
