| Farmall & IHC Tractors Discussion Forum |
Topic: 1947 Farmall B no spark
[Return to Forum]
| Author |
[Modern View]
| Dave H (MI)
12-12-2012 07:44:09
66.87.2.219
Tractor is on 12v. After getting it running and letting her warm up a good 20 minutes. I shut it down. It ran great. After dinner I go to pull it out of the shop and put it away and I am back to no spark. It has new points, plugs, condenser. I have good voltage on both sides of the coil with the side distributor wire disconnected. Snapping the points open does not cause the coil to fire with center lead near ground. I am thinking maybe "old" was right about the insulated stud on the side of the distributor being bad. Anything else I should check? I am chasing phantoms and that tends to end up being weak insulation someplace that shorts randomly. Any thoughts? |
| Mark-Ia
12-12-2012 10:49:58
207.177.117.7
Re: 1947 Farmall B no spark in reply to Dave H (MI), 12-12-2012 07:44:09
| sometimes the spring on the points will touch a screw head or something. that will kill your spark. |
| John T
12-12-2012 12:30:54
216.249.82.117
Re: 1947 Farmall B no spark in reply to Mark-Ia, 12-12-2012 10:49:58
| | Sure enough, Ive seen that happen John T |
| Dave H (MI)
12-12-2012 18:56:44
66.87.7.28
Re: 1947 Farmall B no spark in reply to John T, 12-12-2012 12:30:54
| | And mayhap you have again. I was out there looking at all the possibilities inside the distributor and, just because he mentioned it, I gave the spring for the points a once over and it looked like it may be too close to the back of the distributor. I pried it forward a bit and reassembled and it fired up...reluctantly because the plugs were fouled again. Just went out this evening and it started right up and backed into the shop for the night. Now it stopped dead while I was closing the overhead door leading me to believe that I will be looking at it again on Friday. But for tonight I decided not to go looking for trouble. I have all your posts and notes copied into my archives for future reference. Many thanks to all for the help! |
| old
12-12-2012 08:50:37
4.244.219.117
| As I said the other day move the crank so the points are open. Take one of the 2 small wires off the coil does not matter which one be it distributor side or ignition side and if you get a spark when you hook and unhook that wire you have a short in the distributor be it the insulator or you have one of the wires from the condenser etc shorting out. No test light needed but you do need to be where the sun light is not so bright as to hide the small spark that you should not see |
| Dave H (MI)
12-12-2012 10:10:13
66.87.0.15
Re: 1947 Farmall B no spark in reply to old, 12-12-2012 08:50:37
| Thanks Rich, I think I was pretty clear that I have it narrowed down to a short in the distributor. I don't really see a lot of places other than the stud for there to be a short. The points/condensor are new. I'll have to have a look around in there and see if there is something making contact that should not be. I suppose that jumper from the coil to points could be shorting to the distributor housing too. That would be a good source since it it is an on again off again problem I am thinking the wire could be a likely culprit. Appreciate your thoughts. |
| stumper
12-12-2012 16:43:33
216.118.223.9
Re: 1947 Farmall B no spark in reply to Dave H (MI), 12-12-2012 10:10:13
| I have seen new points shorted on the pivot pin so be sure to look at everything, stumper |
| John T
12-12-2012 12:29:55
216.249.82.117
| | The short you suspect ought to be easy to find. An ohm mter or simple continuity tester on the side terminal with other lead to case ground ought to register: CLOSED CIRCUIT SHORT (Low resistance) WHEN POINTS ARE CLOSED AN OPEN CIRCUIT (High approaching infinity resistance) WHEN POINTS ARE OPEN If its ALWAYS is a short to case ground, the problems either: Points are staying closed,,,,,,,,,,Condensor is bad and shorted out (Ive seen new ones out of the box bad and shorted out, try unhooking it n see if that fixes the short) ,,,,,,,,,,,Wires to condensor or points are shorted out to case ground,,,,,,,,,,,,,Points have a short (I have seen the springs shorted),,,,,,,,,,,,Side pass through insulated bushing terminal (where coil wire attaches) is shorted out. Once more,,,,,,,,,,, a simple cheap DC test lamp placed on the distributors terminal or on the coils output with ignition on and if all else is wired correct and working SHOULD LIGHT UP WHEN POINTS ARE OPEN AND GO OFF WHEN THEY ARE CLOSED and if not re read my post below to see why and the possible problems HOPE THIS HELPS, LET US KNOW WHAT YOU FIND God Bless n best wishes John T |
| old
12-12-2012 11:47:38
209.86.226.19
| If you have that spark as I said when you unhook and hook the wire to the coil then remove the wire from the points and make sure it is not touching any thing. If you still get that spark then it is a bad insulator going in the side of the distributor. If that is so what I do is remove the insulator then run a wire in the side of the distributor and seal that wire off with silicone then it is a fixed problem unless your wanting it to look like it was new. I have a ford 841 that has been set up that way for well over 25 years now |
| John T
12-12-2012 08:18:19
216.249.82.117
| | Seems like yours or a similar question was posted a few days back?????? IFFFFFFFFFF the distributors insulated pass through stu/terminal is indeed shorted out as you mentioned, she will never fire and a test lamp on the coils output (to distributor) terminal when wired up to distributor WILL NEVER LIGHT UP SEE BELOW!!!!!!!!!!!!!!!!! Here are the tips I posted then, which of course, includes info about the distributors insulated side pass through insulated bushing possibly being shorted as a possible (along with several other) cause. 1) With the ignition on there should ALWAYS be voltage (with respect to frame ground) on the hot INPUT (NOT to distributor) side of the coil..... 2) Over on the coils other OUTPUT terminal: Hot battery voltage when points are open ZERO volts when points are closed Therefore, if the engine is cranked over slowly a test lamp on the coils output (to distributor) should flash ON (points open) and OFF (points closed) If the lamp never goes off (should when points are closed) the points arent fully closing or,,,,,,,,,,,,,, are burned/carboned severely and not conducting or,,,,,,,,,, the points or distributor isnt well grounded If the lamp never comes on (and all else is okay), condensor is shorted,,,,,,, or points are shorted out or remain closed,,,,,,, or points or condensor wires are shorted or,,,,,,,,,,, the distributors insulated side pass through stud/terminal is shorted or else the coils LV primary is bad/open Work through this for more tips and diagnosis http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=5745
John T |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
