Anonymous-0
I have an IH 544 with a Delco Remy 1112697 distributor (cap held on by screws). The tractor started fine but would sometimes stop after a couple hours but could be restarted, so the Case dealer recommended a tune up. I replaced the plugs, wires, distributor cap and rotor.
After the tune up, the tractor will only start if I use the old somewhat corroded and cracked distributer cap, but not the new one (have tried 2 new ones from the Case dealer). With the new cap, it sounds like a spark is only going to 1 cylinder when I try to start it. Does anyone have any ideas?
Thanks in advance for any help.
Paul
Paul
