MSM
Can anyone give me an accurate width,length and weight of a W450 diesel. No fluid in the tires,no weights. Trying to get one hauled and trucker needs dimensions. Thanks
130" long approx 82" wide and 92" tall depending on your muffler. As far as the weight my W400D which should be about the same weighs approx 7000lbs
Did you get that one that was on Ebay? We have a narrow 450diesel. They are a cool machine to run. I drove ours home from an auction 5 1/2 hours of great scenery!
The W 450 is listed under International but doesn't give any dimensions or weight. Looking at the W400 (basically the same tractor), the weight at the light end is a little under 6200 lbs. I would assume that is without ballast, weights and no fluids.
