Installing the front gas tank mount on an F 20
SDE
50/50 chance to get it right. Which side of the tractor does the longer lever go on? The right or the left?
Thank you
SDE
It depend on if you have the cross over Z bar that goes in front of the tank. Left with the cross bar. Right if no cross bar. there are different set ups with year. Also some were changed to veriable speed govenors so that kit also changed things. oldiron29
Thank you, I have not gotten to the point of connecting any rods to anything. I don't even have the carb. on the manifold yet, but I did want to put the gas tank on.
SDE
Like oldiron said it depends. What year is it ? If its 37 or newer probably the left, it older it may have the variable speed gov update kit and go on the right. I have a 36 out in my garage now with the vriable update and right hand throttle setup on it so if you need some pics just holler and I will go take some.
