Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: What Oil in A Transmission and Final Drive
gene bender
12-05-2012 02:24:18
I drain them and put a couple gal of Diesel drive around a bit tne drain and flush then refil with 90 wt. The level plug is behind the brake rod on the left side of the tranny. Tranny and final are in the same casting. So pour in thru the plug on top of the tranny till it comes out the level plug and you are fit to go.
Erik Dekeyser
12-05-2012 02:56:45
 Re: What Oil in A Transmission and Final Drive in reply to gene bender, 12-05-2012 02:24:18
Gene isnt the final drives on the A and the 140 seperate? I usually take the final drive pans of and refill them in the plug just above the pans with 80w90 oil.
gene bender
12-05-2012 03:30:39
 Re: What Oil in A Transmission and Final Drive in reply to Erik Dekeyser, 12-05-2012 02:56:45
Yes i was thinking about the diff drive. With out a doubt the finals are different. By the way the finals sure arent very nice to service i guess thats why lots are dry. Some think the finals can just use grease but that will not lube the top bearing of the diff shaft or the gear on that shaft.
