Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: farmall bn won't start.
CNKS
12-04-2012 17:14:33
It dripped gas on the ground because you gave it too much choke. If you have never worked on the carb, it is due disassembly and a good cleaning with real carb cleaner, followed by a complete CaseIH carb kit. The Marvel Schebel(sp?) is in the parts manual, also in the parts section of of CaseIH.com. If you have good spark, I am assuming you have not messed with the timing recently.
will k
12-08-2012 09:55:37
 Re: farmall bn won't start. in reply to CNKS, 12-04-2012 17:14:33
Checked the compression/spark - timing seems to be right. Removed the carburetor. It was so full of grime and varnish I soaked it in gas for 2 days. Next, I used carb and choke cleaner on it. It"s orange, must be off an old allis. It is a TSX 422. Went to parts store, and got a rebuild kit. Changed out all parts that were in the kit. The gasket that goes between the halves was so brittle, that it broke in two spots. I used it anyway. Gas tank will be a big job also. I hope to do something with it tomorrow. Any other suggestions?
Copyright © 1997-2015 Yesterday's Tractor Co.
