Picklesmith
New User
I have a 1948 Farmall M with the LiftAll accessory. I need assistance concerning how to configure or connect the hydraulic hose(s) from the liftall to a single hydraulic cylindar on a towed John Deere #55 plow. The problem I am having is that using only one hose from the liftall to the cylindar allows me to lift the plow but, I have to rely on gravity to drop the plow. In this configuration, I cannot quite get the plow to "dig in" when plowing. When I connect two hoses to the lift all (using A&B ports on the liftall), I cannot lift or lower the plow very well. The cylindar on the plow is a 3x8 off-the-shelf type item and not the cylindar that JD apparently had as original equipment on the plow. Any assistance would be appreciated.
