TractorLinks.com
Show Parts for Model:
Re: Turning a crankshaft
mike1972chev
12-04-2012 06:03:25
The BEST machine shops will usually refuse to do machine work WITH OUT the new replacement parts in hand. Tolerances could be slightly off.The BEST guys are checking everything BEFORE turning them down.If not,you can end up with sloppy machine work,or even worse,a "junk" un useable crank shaft. If they ARE a GOOD shop,they should be able to produce any engine bearing made.If not,I would question their back ground in doing crank shafts myself.
BTW,My engine guy WILL NOT EVEN think about boring a block with out the new pistons,or any other major work with out the replacement parts sitting right there with him.
