grill surround
Old, you know some of us do not know but it probably will. If I were in your shoes I would check the part numbers for both. If the same then your answer is yes.
Lmack, part # 362586R91 230
362584R91 100 Different part # but they look exactly the same. oldiron29
If it fits bolt it up. The only difference is the stering bolster and the cultivator frame adaptors for the two tractors. That could cause there to be a slight diffence in overall length and shape of the tin. Larry :)
