super c steering
blunted
with new bearing, bushing, and seal on worm shaft, is there a spot for the worm gear sits to be coherant with the big gear? thanks
To the best of my knowledge, the assembly can go together only one way. Thus when the bearing is installed, and (if shims were found, they were returned to the original configuration) it will be correct. Jim
thanks, jim. i know, takeing the yoke off, at first to get puller on the yoke, had to hit on the shaft as keeping the yoke against the houseing thus having to turn yoke so it stayed against the houseing thus, changeing the position between worm gear and the big gear. thanks. just dont make any thing tight. thanks
