Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Turning a crankshaft
[Return to Forum]
Fritz Maurer
12-03-2012 18:52:41
216.137.138.146
How does a machinist know the diameter of the next undersize? I'm taking a crank to a shop who probably does not have a listing for a W-12. I was planning on getting the bearings from Rice's, but I am hesitant to have them provide the dimensions to the machinist; if the crank turns out wrong, I'm stuck with it. I would rather the guy doing the job find out for himself. I have never heard of a crank being refused for lack of information, that's why I wondered if there was some other way of checking the diameter. Thanks, Fritz
[Reply]   [No Email]
Bill Krosnicki
12-05-2012 07:59:24
50.124.48.137
Re: Turning a crankshaft in reply to Lucid, 12-03-2012 18:52:41
I'm pretty sure he can get them, the w-12 has the same engine as the F-12 and parts for them are widely available.
  [Reply]  [No Email]
El Toro
12-04-2012 13:57:38
108.3.143.30
Re: Turning a crankshaft in reply to Fritz Maurer, 12-03-2012 18:52:41
The machinist should have a manual that covers all or most farm tractors. Hal
  [Reply]  [No Email]
ihcowner
12-04-2012 12:20:14
99.197.107.145
A W-12 has the same diameters as the A,B,C, cranks. The rod bearings are the exact same and the mains will work with a little grinding.
  [Reply]  [No Email]
teddy52food
12-05-2012 06:37:42
184.94.175.179
Re: Turning a crankshaft in reply to ihcowner, 12-04-2012 12:20:14
Just from memory , rods are 1.7495 & mains are 2.1245.
  [Reply]  [No Email]
gene bender
12-04-2012 06:48:30
207.177.56.85
Let the machine shop take care of the bearings or just let them turn it so its ready for the new bearings if it has to turned over 30 thous get another crank. They will know what the specs are.
  [Reply]  [No Email]
mike1972chev
12-04-2012 06:03:25
75.149.81.173
The BEST machine shops will usually refuse to do machine work WITH OUT the new replacement parts in hand. Tolerances could be slightly off.The BEST guys are checking everything BEFORE turning them down.If not,you can end up with sloppy machine work,or even worse,a "junk" un useable crank shaft. If they ARE a GOOD shop,they should be able to produce any engine bearing made.If not,I would question their back ground in doing crank shafts myself.
BTW,My engine guy WILL NOT EVEN think about boring a block with out the new pistons,or any other major work with out the replacement parts sitting right there with him.
  [Reply]  [No Email]
Notjustair
12-03-2012 19:40:18
174.255.3.170
I have always either had the machinest supply me with bearings after doing the grinding or write down EXACTLY what I am to get. It seems like you are putting the cart before the horse.
  [Reply]  [No Email]
Fritz Maurer
12-03-2012 19:57:17
216.137.138.146
Re: Turning a crankshaft in reply to Notjustair, 12-03-2012 19:40:18
What * if * he * can't * get * them ?
  [Reply]  [No Email]
Owen Aaland
12-03-2012 20:11:41
216.47.35.179
Re: Turning a crankshaft in reply to Fritz Maurer, 12-03-2012 19:57:17
He starts by checking to see what is available for bearings before turning the shaft.
  [Reply]  [No Email]
teddy52food
12-03-2012 19:32:20
184.94.175.179
I used to grind shafts. We had a book that had the forging numbers of cranks and the specs. Journal sizes and stroke . Also listed the undersizes of bearings available. A shop with a grinder will have the info too.
  [Reply]  [No Email]
Earl-IL
12-03-2012 19:26:29
50.81.209.158
Email sent on specifications. Earl
  [Reply]  [No Email]
David G
12-03-2012 18:55:33
205.215.206.18
There are reference books for crankshafts that the machinists will use.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
