Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: farmall f-12 cooling fan
Ron W
12-03-2012 12:09:56
I don"t know about your f-12, but the nine I have do not have a grease fitting on the fan. Instead there is a slotted set screw that you take out and pour in oil. at the back of the shaft should be a cork or felt washer/seal to keep it in. It doesn"t take much oil to keep it well lubed.
cphillips
12-03-2012 12:58:10
 Re: farmall f-12 cooling fan in reply to Ron W, 12-03-2012 12:09:56
I'll call fordson house tomorrow, mine has a zerk for grease on it. I used high temp synthetic grease sparingly but it still flows out. I think it may be the seal you are talking about because it seems to be getting worse the more I run it.
Ron W
12-03-2012 12:12:50
If you call Rice, equipment, or go to Fordson House, you can get the cork gasket/seal:
11154-V Fan Hub Gasket (Cork)
11155-V Cork Washer
https://www.thefordsonhouse.com/storefront.asp?cat=1
Copyright © 1997-2015 Yesterday's Tractor Co.
