Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: which coil-electronic ignition
Janicholson
12-02-2012 20:52:43
The issue is a coil that matches the voltage. A 2 ohm coil should work. a 1.5 will work but draw a lot of current. Read the directions well. If it is 12 volt, a 3 ohm coil is more like it. I think something else is wrong, timing, or firing order or something. Was the reluctor (over the cam) set to the correct distance from the sensor. Was there a ballast resistor in the circuit that was left in, and supposed to be removed? was the bushing in the distributor OK, less -- than .001 runout? Check the directions. Jim
