TractorLinks.com
Show Parts for Model:
Re: Farmall Super-A transmission problem, please help
pete 23
12-02-2012 18:19:55
Did you measure the back lash of ring and pinion with the old bearings intact. You may have been noisy from worn bearings but the new bearings put a different pattern on the ring gear. The depth of the pinion is set by the shims under that front bearing retainer on lower transmission shaft. Like I said before, it is difficult to get at to even see that pinion depth when it is once installed and you have to know what the pattern should look like to adjust it properly. Usually, just using original shims will get you by BUT like others have said, have you ever heard a really quiet one. Heck, it is hard to get one set that is easily visible on the top shaft pinion set up like the larger tractors use. You could take that lower shaft cap off and feel the back lash. That would give you an idea if it is too tight or too loose.
From your description of the noise I would say it all comes down to mesh of the pinion. Few years ago I put a whole bunch of gears into a different rear housing on a Farmall A and I thought I had it pretty darn good but the guy complained. Didn't sound unusual at all to me.
Gary730
12-03-2012 03:06:13
 Re: Farmall Super-A transmission problem, please help in reply to pete 23, 12-02-2012 18:19:55
Thanks Pete, This is the way I'm thinking I need to go. Can you email me, and maybe give me a phone number...I would like very much to be able to talk to you on the phone.
